It is currently Sun Jun 22, 2025 4:04 pm
PostPosted: Sat Feb 11, 2006 3:34 pm
First name: Larry
Last Name: Hawes
I have lost my Martin template and measurements for my kit's standard peghead and have also purchased some Grover Sta Tite tuners from StewMac. I cannot, for the last half hour of web surfing, find any basic measurements and istallation insructions on the web.
Any help?
Specifically spacing of the tuners and drill sizes and basics for the Grovers. Even a Grover web site might help.
Thanks in advance
Larry
Finally found the Grover site but still need tuner spacing if possible?
Grover Web SiteLarryH38759.9971296296
Thank You and Best To All
PostPosted: Sat Feb 11, 2006 5:24 pm
I'm not in my shop at the moment but it seems to me that the holes were space at 1 3/8" and 1/2" in from the edge. You may want to get a second opinion though because this is from memory.
PostPosted: Sun Feb 12, 2006 12:12 am
John's measurements sound right. Martin offsets the A and B tuners
toward the center of the peghead (maybe 1/16) so that the A and B
strings do not touch the E strings posts.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sun Feb 12, 2006 12:20 am
For a standard Martin-esque headstock I usually put them 1/2" in and 1 1/2" apart. But depending on the taper of your headstock you should trace it and draw it out first so you don't end up with a problem later.
PostPosted: Sun Feb 12, 2006 4:58 am
I'm with Brock on this one!
1 1/2" apart and 1/2" from the edges!
I would be more concerned with the distance from the edges so the tuners fit right....the distance beteween them doesn't really matter as long as you keep them the same between all of them!
PostPosted: Sun Feb 12, 2006 9:13 am
First name: Larry
Last Name: Hawes
Thanks a ton you guys - much appreciated.
Larry
PostPosted: Sat Feb 18, 2006 5:29 am
First name: Larry
Last Name: Hawes
Sorry to rehash this but the spacing recommendations seem no where near the peghead I have or the pic below. The spacing at 1 1/2" leaves a LOT of room at the top and bottom of the peghead and it looks like the pic is closer to 1 3/4" - 2" apart.
Also the 2 E strings are closer to the edge than the other 4. It even looks like all 3 tuners have their unique spacing from the edge.
I can't find my Martin template, nor a template or measurements on line, just sold my Martin dread, and can't start drilling without some more info.
Does anyone have a Martin standard peghead or maybe a bit more info on actual measurements before I make a large mistake?
Larry
PostPosted: Sat Feb 18, 2006 6:00 am
First name: Larry
Last Name: Hawes
Found my template. Hope this might help someone else.
Larry
